Uh Oh..got some fuel under the bonnet
Old May 11, 2011 | 09:25 PM
tsingtao35's Avatar
Default Uh Oh..got some fuel under the bonnet
I went to start the car today and immediately smelling gas fumes, opened the hood and saw gas on the valve cover near the firewall. Any ideas what this might be? I think I will have it towed in tomorrow, seams like a recipe for disaster if I try to drive it there.
Old May 11, 2011 | 10:09 PM
Doug's Avatar
One of the injector hoses, I'll bet. Replace 'em all while your luck is holding out.
-6 injector hoses +1 cold start injector hose
-Fuel supply hose into the fuel rail
-Small hose at pressure regulator
-Small hose at front of cylinder head
-Two hoses at the fuel cooler
-Return hose to the tanks
I think that covers it!
Old May 11, 2011 | 11:00 PM
pdog2000's Avatar
good luck...I hate dealing with gas
Old May 11, 2011 | 11:28 PM
tsingtao35's Avatar
Is this a big job?
Old May 11, 2011 | 11:43 PM
Doug's Avatar
Originally Posted by tsingtao35
Is this a big job?
Nah. Three hours or so. No biggie.
Old May 14, 2011 | 06:49 AM
ronin's Avatar
I want to do the same thing to my car as preventative maintenance while I am swapping out my vacuum lines and have a little more open space. I have located all the other fuel lines, but can you tell me where the ones listed above are located? I've tried following the fuel line around the engine bay but lose the path once it heads under the smog pump.
Thanks,
Eric
Old May 17, 2011 | 09:28 PM
tsingtao35's Avatar
Fixed my issue, it was the top hose very noticeable. Just replaced that one though, not everything.
dsnyder586
Dec 29, 2024 07:39 PM
JWheeler
Nov 22, 2019 08:28 AM
49Markvman
E type ( XK-E )
Sep 21, 2015 06:26 AM
RoyLittle0
Sep 17, 2015 01:05 PM
