Urgent: Timing Help: Urgent
Old Jul 27, 2009 | 10:18 PM
bbarcher's Avatar
Without looking at the manual, I will offer this basic info. It sounds like the camshaft was not in the correct position. The exhaust valve must have been open too far and contacted the piston. Recheck the book, I would think that both valves should have been closed, as if the piston had just reached top dead center on the compression (both valves closed) stroke.
Otherwise, there is possibly not enough piston-to-valve clearance. But that would result from milling material off the flat surface of the head or block. Or it could result from changing to a higher lift cam.
I have a Haynes manual I can dig up tomorrow and see if it has the procedure. What manual did you use?
dsnyder586
Dec 29, 2024 07:39 PM
Wolfy
May 28, 2024 08:06 AM
PMKimpton
Aug 3, 2019 08:22 PM
nitrolouie2142
Sep 5, 2015 01:55 PM
Sprayall
Sep 3, 2015 07:49 PM
