V12 harness
Old Feb 12, 2018 | 03:37 PM
Jaguarxjs1986's Avatar
Default V12 harness
Hi all
I need a new cable for my XJ Series 3 V12 1984.
The cable runs from the right inner wing to ignition, kick down switch, oil temperature, oil pressure gauge, maybe to the generator and it runs down to the automatic transmission.
I have contact with British Wirering but unsuccessfully.
Can anyone help - where do I get a new or a used in a good shape?
Soren Post
Denmark.
Old Feb 13, 2018 | 04:26 AM
I have always made my own, with loom connectors that were readily available down here, and totally different to the originals.
Kind of messy if electrical work is not your preference.
I doubt you will find one in "good" shape, either S3 or XJS (same), as age is against any wiring now.
Old Feb 13, 2018 | 01:08 PM
sidescrollin's Avatar
If you can't find those multi-bullet connections you can always make-up individual bullet connectors, no harm done.
britishwiring should have everything you need to replicate the harness down to the write wire and tracer color.
Old Feb 16, 2018 | 05:17 PM
Jose's Avatar
I just got a tub full of XJ-S V12 ignition parts, like relays, wiring, ECU's, stuff I cannot identify.
I will look to see if I have any harness similar to what you are showing.
JameyXJ6
May 5, 2024 09:12 AM
jal1234
Nov 11, 2018 06:20 PM
Dan Bennett
Mar 27, 2015 05:30 PM
tcpoland
Dec 22, 2013 03:19 PM
Stevecosta
Jun 15, 2013 04:30 PM
