V12 with Magnetti Marelli what goes where
Old Feb 8, 2017 | 10:53 AM
jags3v12's Avatar
Default V12 with Magnetti Marelli what goes where
Hi all,
I use an XJS engine with a Magnetti Marelli system to manage full and ignition on my XKE/E Type under restoration.
I'm ok (until now) with the electrical side of the job. Same for mechanical.
My concern is where go all the hoses around the A bank.
I would like to find picture or a drawing showing where/how are the different parts plugged.
Hope my request is clear.
Thank you all for your returns ( hope to have some)
Old Feb 11, 2017 | 08:47 AM
MLBS3V12's Avatar
I've finally found what goes where except the 2 hoses connected to the distributor.
One is fitted with a filter.
At least hope to have someone who could help only for the 2 hoses. Please!
Old Feb 11, 2017 | 09:10 AM
Doug's Avatar
These illustrations show the distributor vent hoses
Extra Air Valve-V12 - Parts For XJS from (V)179737 to (V)226645 | Jaguar Classic Parts UK
Distributor-5.3/6.0 Litre - Parts For XJS from (V)179737 to (V)226645 | Jaguar Classic Parts UK
Old Feb 11, 2017 | 09:57 AM
MLBS3V12's Avatar
thank you Doug for your help.
This clarify where one goes to the extra air valve. But I still dont know where is the filter on the second hose connceted to. Do you know that ?
Michel
Old Feb 11, 2017 | 10:16 AM
Doug's Avatar
One nipple of the filter is simply left open....no hose attached.
The other nipple has a hose attached that goes to the distributor as per the illustration
The filter itself is situated right where the diagonal fender brace joins the fender, loosely held in place with a wire tie.
