VIN (Vehicle Identification Number) Stamp On Engine
Old May 31, 2015 | 09:07 AM
JgrV12's Avatar
Default VIN (Vehicle Identification Number) Stamp On Engine
Hello Folks,
I have a Series III XJ12. Does anybody know where I can find the VIN (Vehicle Identification Number) stamp on the actual motor of the car itself? I paid somebody to swap out a different motor for me because the original had a blown head gasket. I had a friend check out the new motor recently because of a major coolant leak and this new motor has a blown head gasket as well.
I want to compare the VIN stamp on the new motor with that of the car itself. I am wondering if the motor was ever changed to begin with...
Thank you!
Old May 31, 2015 | 10:32 AM
Doug's Avatar
We'll wait for others to verify but I'm 99% that Jaguar never stamped engines with the car's VIN or even portion of the VIN. There is an engine number, though.
However, you could get a Heritage Certificate from Jaguar which shows the *original engine number* . From there you can obviously tell if the engine has been swapped
Old May 31, 2015 | 11:05 AM
Jose's Avatar
Doug is correct, there is no VIN number on the engine, VIN refers to Vehicle Identification Number, i.e., the car itself, with all its assemblies together as it left the assembly line under its own power.
there is a Engine Number on the engine itself, as well as a Cylinder Head Number on the cylinder head, (well at least in older Jaguars there was a cylinder head number).
the engine number is located on the right side of the block, towards the rear, towards the bottom, above the oil filter head on the block "lip" where the oil pan is bolted to.
Old May 31, 2015 | 11:41 AM
JgrV12's Avatar
Thank you Doug and Jose for your help!
Old May 31, 2015 | 12:00 PM
Doug's Avatar
On a V12 the engine number is at the rear of the "Vee", near the oil pressure sending unit
Old Jun 1, 2015 | 12:02 PM
JagCad's Avatar
Wowee, the "mother of all wall jobs" !!! Throw in some Kwik seal or other snake oil.
Charge for swap. Hope it works????
Aside from the numbers, I wonder if you might recognize your "old" motor as still residing in the bay. Some individuality. In my case, a dent in the sump[!!!
Carl
Old Jun 1, 2015 | 01:47 PM
JgrV12's Avatar
I wish I took some photos of the motor before sending it in for the swap. I sent the car in shortly after purchasing it. The Lucas control unit sticker reminds me of the one in the old motor (scratching on sticker), but I can't prove that or be certain without a photo of the old motor.
D.K
Dec 10, 2023 02:05 AM
Sprayall
May 30, 2021 08:13 AM
Sprayall
Sep 3, 2015 07:49 PM
XFR_Gold
Sep 2, 2015 12:24 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
