VJ12 H.E Fuel pressure regulators
Old Dec 16, 2023 | 02:47 PM
mb_asasello's Avatar
Default VJ12 H.E Fuel pressure regulators
Hi guys, I'm currently restoring 1982 Daimler Double Six. I have a question about fuel pressure regulators. I've read, that you can get rid of one of them and there are no side effects and engine runs smoother. Which one is it? Does anyone can help me with part numbers?
If I understand correctly LH one is 0280160234 / 73239B / EBC 2606 running at 3.0 bar - and this one stays,
and RH is
0280160229 / 73232B / EAC 4864 - this one is to be removed?
Did I get it right?
Thanks in advance
Old Dec 16, 2023 | 04:22 PM
Doug's Avatar
'Tis the RH/inlet regulator that can be eliminated. I wouldn't count on smoother running by simply removing it unless, of course, it is faulty in some way.
This assumes you have the HE engine. You almost certainly do. But the Pre-HE/HE change was mid 1981 and model year designations can become blurry given country-by-country differences in these things.
Old Dec 17, 2023 | 09:56 AM
Yes, I'm 100% positive it is HE engine
Old Dec 17, 2023 | 08:59 PM
Have a read. I wrote this looong ago.
The 2nd PDF is a "maybe". Most I have done have required a little trimming.
File Type: pdf
File Type: pdf
Old Dec 18, 2023 | 02:55 AM
Thank you very much, great info. Just to be sure - when we ar talking about righ side we are referring to the right side when driver is sitting behind the wheel?
Best reagrds
Old Dec 18, 2023 | 04:31 AM
ALWAYS.
AKA A Bank, once the Jag lingo takes hold.
lslincoln
Jun 15, 2022 06:37 PM
semmesg
Nov 25, 2020 08:05 PM
VictorLEE
Apr 11, 2016 12:34 AM
SirJag
May 22, 2012 08:16 PM
