Does anyone happen to have fuel pressure specs?
Old May 17, 2012 | 02:13 PM
SirJag's Avatar
Default Does anyone happen to have fuel pressure specs?
.... for a 2001 VDP? Key-forward and engine running fuel-pressure specs?
If so, would you kindly post?
Thanks so much!
SirJag
Old May 17, 2012 | 02:49 PM
BlackX300VDP's Avatar
40-45 psi
Old May 17, 2012 | 06:51 PM
jimlombardi's Avatar
Hi SirJag
Testpoint statement in a July 2011 thread:
The fuel rail pressure should be 41 psi plus/minus a couple, mostly meter error.
Here is PDF file about Fuel System Pressure Check for 2001 XJ (308) extracted from JTIS:
2001 XJ (X308) Fuel pressures.pdf
Jim Lombardi
Old May 18, 2012 | 03:47 AM
SirJag's Avatar
Question Any other way to test fuel pump besides PRESSURE?
Thanks for the numbers, BlackX300VDP, and for the PDF, Jim!
My mechanic mentioned that you can have sufficient pressure, but insufficient volume of fuel pumped. Other than simply checking pressure, is there any other way to test a fuel pump?
In other words, if you get the correct amount of pressure, does that necessarily mean there's no problem with the fuel pump?
Thank you,
SirJag
Old May 18, 2012 | 07:27 AM
Hi
SirJag have you ever replaced the fuel filter that is located just above the rear axle on the driver side? It could be restrict the fuel flow.
Look at post# 4 in this other thread:
https://www.jaguarforums.com/forum/x...ld-easy-70909/
Hope you are able to resolve your rough idle issue soon.
Jim Lombardi
Old May 18, 2012 | 08:01 AM
JimmyL's Avatar
Talking
Good idea to change the fuel filter. It will help your fuel pump last longer. The thing about volume and pressure might apply to electricity (voltage and amperage), but I don't think it applies in the case of fuel, unless your fuel lines have developed arteriosclerosis - narrowing of the fuel lines.
Old May 22, 2012 | 08:16 PM
sbreeden's Avatar
Google search, this is what I founded.
http://www.jagrepair.com/images/TSB/...0Diagnosis.pdf
toronadomike
Jan 22, 2026 10:13 PM
dsnyder586
Dec 29, 2024 07:39 PM
Bcrary3
Feb 21, 2023 04:29 AM
ccfulton
Sep 20, 2015 05:15 PM
hen555
Sep 7, 2015 11:13 PM
