warning lights '74 series 2 XJ6
discovered that three of the lenses have gone astray and two gone adrift from their designated locations. of the two remaining in place, they are the hazard and seat belt warning lights. I need the proper top-to-bottom arrangement in order to put this back together correctly. I have a series 3 donor to source the missing lenses from (yes, I know, they're different styles entirely). Anyone with the proper arrangement scheme handy?
removed the remaining original lenses and trial fitted the series 3 ones; with a little bit of sanding, they fit right into the space provided, leaving a tiny gap at each end which I plan to fill with clear cement, then paint that edge black to contain light within the assembly. I imagine that knowledgeable folks will be scratching their heads later on when they encounter the car... "wrong logos on the warning lights, but the bezel is correct?!?"
99xk8guy
Sep 29, 2025 10:51 PM
