Where to start with slight engine miss
Old Mar 22, 2015 | 05:49 AM
o1xjr's Avatar
Originally Posted by Grant Francis
AH, I miss those SU's. Such SIMPLE things.
I will take that as,yes that is the normal amount of crap to build up in 4-6 months of daily driving.
It started cold perfect and idle was smooth with choke half way out.
Old Mar 22, 2015 | 06:00 AM
Pretty much.
The hose from the front breather does dump a lot of crap on the clean air side of the filter. Most of mine had a simple hose dropped down from that breather and vented to atmosphere. Not good if the engine is a breather, mine were NOT, or emission testing is done.
Those carbies stayed clean for years.
Old Mar 22, 2015 | 06:04 AM
o1xjr's Avatar
Thanks, I'll try the atmospheric venting system. Day off Thursday, so will try it then and report back in six months.
Old Mar 23, 2015 | 04:43 AM
o1xjr's Avatar
Drove it to work today, certainly running smoother and starting easier. Hadn't noticed tuning slowly slipping away, but a clean and mixture and idle set of the mighty SU's has breathed more life into it.
All the better now for the Track Challenge at Lakeside Raceway, if the weather is good at the Euro day I will sign up to do some hot laps(lol)
Old Mar 30, 2015 | 03:12 AM
Daf11e's Avatar
Active Streak: 120 Days
Where to start with slight engine miss-image.jpgWell I decided today was the day for cleaning the carbies and followed instructions. I had to improvise on a couple of things,one the aircon pipes on the engine had to be moved for clearance to remove left dome and also the choke cable went through the lower hole of the same dome so had to be disconnected. Apart from that all went according to plan and now running very well. As can be seen from the piccies God knows when they were last cleaned.....should have it spot on after a couple of tweeks.
Grant that write up allows tinkerers like me to achieve great results....thanks!
Old Mar 30, 2015 | 03:14 AM
Daf11e's Avatar
And this
fast40driver
Apr 19, 2024 07:24 AM
1100me
Aug 27, 2020 11:37 PM
tberg
Sep 7, 2015 07:32 AM
1964Daimler
Sep 2, 2015 11:41 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
