Will S2/S3 front calipers fit on a S1 ??
Old May 7, 2022 | 05:28 PM
Jan Meiling's Avatar
Default Will S2/S3 front calipers fit on a S1 ??
Hi all,
The front "3 piston"-calipers on my '72 S1 are seriously bad.
Can i just fit "4-piston" S2/S3 calipers? I do realise and accept that i will also have to switch to 24mm discs)
I do read suggestions here and there to replace the whole hub/spindle to a S3 model. But is this strictly necessary if you want to move from a "3-piston caliper / 12mm disc" to a "4-piston caliper/ 24mm disc" configuration on a Series 1 car?
Or can i just swap the calipers and disc ?
Thanks so much !
Jan
Old May 7, 2022 | 06:02 PM
Robert Laughton's Avatar
The S1 brakes are good unless neglected.
To swap to 4 pot, everything between the upper and lower ball joint has to be changed as well.
And some advocate then swapping to a S3 master as well, which matches the calipers.
Rob
vincent661983
Nov 15, 2021 02:57 PM
rwolak
Mar 18, 2020 06:00 AM
bsracer
Mark V - X 420G
Apr 3, 2017 06:29 PM
bazjag
E type ( XK-E )
Feb 15, 2017 11:19 PM
Bobbimack
Nov 12, 2012 06:29 PM
