Window wipers - 1986 XJ6
Old Dec 23, 2023 | 01:10 AM
1987JaguarXJ6's Avatar
Default Window wipers - 1986 XJ6
Has anyone else had issues with window wipers, not working? my mechanic can’t seem to figure out what’s going on. It doesn’t seem to be the motor.
can anyone give me a little guidance on what I should have checked out? Thanks a bunch!
Old Dec 23, 2023 | 03:50 AM
Malcolm Ridgway's Avatar
Default Windscreen wipers not working
[QUOTE=1987JaguarXJ6;2706179]Has anyone else had issues with window wipers, not working? my mechanic can’t seem to figure out what’s going on. It doesn’t seem to be the motor.
[Check and clean any wiring connections and the fuse box. Was the problem with my front lights and electric mirrors.
Old Dec 23, 2023 | 04:24 AM
Greg in France's Avatar
What is the problem, refusal to work at all?
Old Dec 23, 2023 | 07:34 AM
Doug's Avatar
Agreed on fuses and connections.
If no joy then it’s probably the switch… which is a high failure rate part on these cars.
Sometimes the switch can be repaired. I’m sure you’ll find some info in the archives
Old Dec 23, 2023 | 04:22 PM
Jose's Avatar
one way to check is by removing the underdash foam knee panel, then finding and grabbing the harness coming out from behind the wiper switch and wiggling it with engine running and switch in the upper position. Wear and tear.
Old Dec 23, 2023 | 06:17 PM
xjtom's Avatar
Have you disconnected the wiper motor from the rack, then use the wiper switch to test the motor, if it works then it's the rack & pivots
Old Dec 23, 2023 | 09:50 PM
Bill Mac's Avatar
I had an internal rack cable failure some years ago. Motor ran OK but no drive to the wipers.
Old Dec 24, 2023 | 02:03 AM
The parking unit in the motor/drive assembly can fail too, and this permanently stops the motor. This item:
https://www.ebay.co.uk/itm/JAGUAR-DA...-/121561045187
89JAGXJS
Aug 21, 2018 08:35 PM
Spyhunter2k
Jul 9, 2012 02:27 PM
User 432
Dec 18, 2010 11:17 AM
1995XJ609
Jan 28, 2009 04:13 AM
