Wire Spaghetti Console
Old Jan 1, 2024 | 08:31 PM
adenshillito's Avatar
Default Wire Spaghetti Console
fished the wires up from beneath the central console where they haven't been connected up in a while. did a little test to see which ones were live and about four were, purple ones and two white/black ones. there are a good number without homes and a few with odd connectors. got to figure my way back through the Wire Spaghetti .. like one of those maze puzzles you follow with a pen to get out. i like the process of elimination and the avoidance of shocks or fire. Here's some pictures any how.
Old Jan 3, 2024 | 03:03 PM
xjtom's Avatar
so are you i need of a colour schematic? >>> https://www.jaguar-wiring-schematics.info/index.htm
Old Jan 3, 2024 | 09:23 PM
I have a few colour charts, most are fairly directive and clear, but a few things don't loan themselves to explanation readily.
like orange wires (with tracers red/green) not recorded on the chart and a plug for 'dash light' a long way from the dash. and some daisy chain loops no clear direction.
most things follow logics, just a few oddities.
Old Jan 4, 2024 | 03:15 PM
xjtom's Avatar
orange/red & orange / green are for the door lock solenoid relay, dash light (purple (cigar) & purple/white(interior) & red/white) are for the gear shift light & fiber optic distribution....is there a pic of the "daisy chain"? or mark an arrow on the picture.......
Old Jan 5, 2024 | 07:03 PM
ah yes, i should have known the orange/red/green ones as when i latter found the 'button' it had a few attached, thanks for that. i can't figure why some of them have odd connections on the end tho, would have thought they'd all connect to the switch in some manner (see picture)
a connector with a plug (two wires, ground black and a red/white one)
and a single black one with a bullet connector as well (see new pictures)
the button wit the remaining connectors
the solenoid orange/red/greens and the a black grey one with various connectors.
that rough black one with a female bullet head
the two pin with red/white wire
Old Jan 5, 2024 | 08:18 PM
xjtom's Avatar
red/white (black earth) feeds the fiber optic unit which should be near the gear shift, keep in mind that not all wiring is used as - looms are interchanged with different models, obviously some connectors have been changed to after market, bullet connector will take or supply power to another connector, the one that looks like a bullet looks more like a broken F spade, orange/green (X2) one from door lock switch to W2 door lock relay then w1 from relay to door lock solenoids........you mentioned you have some colour schematics, home made or purchased from?
Old Jan 5, 2024 | 08:32 PM
schematics, printed off the internet, i think they're for more than one model perhaps as some times exact and other times not.
fibre optics stuff no longer in this car so would explain way the plug has sat vacant
Old Jan 6, 2024 | 12:03 AM
xjtom's Avatar
do you have a link of the site or sample? schematics
Old Jan 6, 2024 | 11:45 PM
actually i think i might be using the wrong terms, what i have is colour chart listing wire colour rather than a true wiring schematics, see attached.
Old Jan 7, 2024 | 03:04 PM
xjtom's Avatar
i see what you mean, so if you need a colour schematic >>> https://www.jaguar-wiring-schematics.info/index.htm
Mooneych
Jul 31, 2022 06:48 PM
Xjeffs
Jul 18, 2021 03:05 PM
adenshillito
May 5, 2021 09:56 PM
wydopnthrtl
Jun 3, 2019 12:38 PM
Flex320
XJ XJ12 ( X305 )
Apr 25, 2019 03:03 AM
