Wont start!
Old Apr 6, 2014 | 08:59 AM
markmcewan's Avatar
Default Wont start!
Hello everyone. I need some help regarding my '95 XJ6. I have a problem with the car starting when the engine is hot. By "not starting" I mean that the engine won't even crank, if I turn the key and jump the solenoid it will fire right off. I know that it isnt the started because I'm not even getting power to the starter. Also, on a different topic, does anyone know where I can get a harmonic balancer?
Old Apr 6, 2014 | 09:06 AM
Wilfred88's Avatar
if you have a 95 car, you're in the wrong section.
for what it's worth? starter relais?
Old Apr 6, 2014 | 09:23 AM
Doug's Avatar
First.....
When you turn the key "on" does the "P" on the shift indicator glow red? If not, try jiggling the geashift until it does, and then turn the key to 'start'.
If this solves the problem then you need to adjust your linear switch at the geashift.
Lot's of other possibilities, though.
Is yours delaninating? If so, most of us simply send the balancer out to be re-bonded.
I think new balancers are out there for $700-800 but re-bonding is usually about $125-250.
Hopefully an admin will see this thread and move it to the X300 section, which is where it should be if you have a 1995 XJ6
Old Apr 7, 2014 | 05:46 AM
markmcewan's Avatar
Thank you very much. I will repost in the correct location but could you tell me where I can get my balancer rebonded?
Old Apr 7, 2014 | 06:55 AM
Doug's Avatar
Many use this outfit with good results
DamperDoctor
I've used this guy a few times and am very pleased. Don't be put off by the horrible webpage
http://hbrepair.com/
Dagny
Jun 11, 2024 01:06 PM
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
Bones
Sep 8, 2015 08:34 PM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
