Won't start when engine cold. new Idle Microswitch XJ6 4.2 1985, 135k miles.
Old 10-07-2009, 09:02 AM
BrightonRay's Avatar
Exclamation Won't start when engine cold. new Idle Microswitch XJ6 4.2 1985, 135k miles.
Won't start when engine cold, first thing in the morning. new Idle Microswitch XJ6 4.2 1985, 135k miles.
We recently installed a new Idle Microswitch on my XJ6 4.2 1985, 135k miles. And we confirmed that it is making contact with an ohmmeter.
It does fire up but sounds like it is going to die.
then when I press the pedal the rpms go up, and it runs rough.
But when I let off the gas it dies completely.
Can someone suggest what to look into, or how to readjust the mixture settings with the Idle Microswitch in the circuit?
If I take the lead off the Idle Microswitch it runs smooth, and can drive around.
Then if I put the Idle Microswitch lead back on, it will start ok hot.
Problem occurs only when engine is cold, first thing in the morning.
The car was running fine prior to replacing the Idle Microswitch.
Everything has been replaced on the temp rail and new fuel regulator.
Thx in advance.
BrightonRay
Old 10-07-2009, 09:37 PM
m0t0rm0uth's Avatar
Maybe your microswitch isn't set right? Who makes it?
RaceDiagnostics
12-11-2015 10:12 AM
johanasu
09-03-2015 12:39 PM
1964Daimler
09-02-2015 11:41 PM
Rusty1952
09-01-2015 05:45 AM
Drew2006
08-28-2015 04:22 PM
Quick Reply: Won't start when engine cold. new Idle Microswitch XJ6 4.2 1985, 135k miles.
