XJ6 exhaust system
Old Jan 7, 2015 | 11:11 AM
314jjwalls's Avatar
Default XJ6 exhaust system
Does anyone know when Jaguar, specifically 1974 XJ6 started using catalytic reactors? Any help would be appreciated.
TNX Jack
Old Jan 9, 2015 | 07:10 AM
Darrenmb's Avatar
Veteran: Navy
Are you looking to replace it? delete it? or just see if your car is supposed to have it?
As i am reading it, i see that 74 and older cars are exempt from smog check!
Old Jan 9, 2015 | 07:43 AM
Jose's Avatar
1975 was the first year in US car production.
Old Jan 9, 2015 | 01:28 PM
Giovanni LiCalsi's Avatar
1975 and earlier cars are not required to have a smog test, in California.
My 1975 XJC-6 runs cleaner with all the smog components removed.
I have installed HD-8 SU carbs. Much better than the Zenith Strombergs.
Old Jan 10, 2015 | 03:39 PM
314jjwalls's Avatar
Darren,
Thank you for responding. I have a 1974 xj6L with a chev 300hp 350. It still has the original exhaust system. I am looking to go 2.5 inch with duals the entire system. Right now the jag is quieter than my Grand Cherokee. The new system should add some degree of performance. I am in Oregon with no smog testing, however, the muffler shops are somewhat reticent to install a modified exhaust if the vehicle came with a Catalytic converter. I have been able to determine, with your and others help on the forum that 75 was the first year for Jag's. I have had several other's a 120, and a 140. Loved them. The combination I have now is very reliable and smooth. I am also very familiar with the small block chev. Thank you again.
jack
Old Jan 10, 2015 | 05:47 PM
314jjwalls's Avatar
Darren, Since I am new to the forum I don't know the in's and outs. Such as how do I post a thank you? Any help is appreciated.
tnx
Jack
Old Jan 10, 2015 | 10:00 PM
anjum's Avatar
You've just done it!
The other way is to click on the thanks button at the bottom right of the appropriate post.
rusty37
Apr 5, 2020 07:40 PM
Daim
Nov 28, 2016 09:28 AM
carcycle
Sep 7, 2015 04:14 AM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
