XJ6 S3 - Can't find fuel Filter
Old Nov 28, 2014 | 05:04 PM
fsmo's Avatar
Default XJ6 S3 - Can't find fuel Filter
My S3 Daimler Sovereign (May 1981 - Australian delivery) has no fuel filter in the Tyre well - I have seen other S3 XJ6's with a bracket and large filter in the front R corner of the spare wheel well. Mine just has fuel pipes there.
There are 2 small in-line pre-filters for each tank before the fuel pump, but given she is a fuel injected 4.2, there MUST be a decent fuel filter somewhere - simply can't find it.
Any ideas on where it might be, or where I can add a fuel filter would be appreciated.
Old Nov 29, 2014 | 07:43 AM
Firstly you are NEW, so welcome.
Please do an Intro in the New Members Area when you get the chance.
I have never seen a S3 with factory fitted pre pump filters, so they are an owner fit.
If the filter is not where you and I believe it should be, is it right at the pump, under that other trim panel at the rear of the boot area, basically rearward of the spare wheel??.
Look under the bonnet, where the supply pipe enters the engine bay just under the brake booster, maybe, but I doubt it.
Failing that, you no got one.
Old Nov 29, 2014 | 09:30 AM
JagCad's Avatar
I suspect someone saved a bit of coin of the realm little pre cost a lot less than the big OEM Jaguar unit. Or, that guy decided two before the pump was a better design, by protecting the pump.
Now, I've read of others installing pre pump filters to assist cleaning out rusty tanks.
And protect the pump from detritus.
I kinda like the belt and suspenders idea. But, mine got a new OEM a decade or so ago and has done just fine with it alone. It came with a box of stuff from a guy that sold off his S3.
Carl
Old Nov 30, 2014 | 05:13 AM
fsmo's Avatar
Thanks Carl.
I'm hoping the main fuel filter is near the fuel pump - must admit I didn't look closely there. Will check in the next day or so.
Old Nov 30, 2014 | 05:14 AM
fsmo's Avatar
Sorry, previous post was for Grant.
Old Nov 30, 2014 | 05:17 AM
fsmo's Avatar
Hi Carl,
Yes, I'm told the 2 small filters are owner installed to pre-filter rust etc. from the tanks before the fuel pump and are sourced as a Volvo part originally.
BUT, there still should be a main fuel filter post fuel pump. I'll keep looking!
Old Nov 30, 2014 | 08:19 AM
Doug's Avatar
Originally Posted by fsmo
Hi Carl,
My guess is that the previous owner decided the two pre-pump filters were enough and eliminated the post-pump filter entirely.
I once worked on a very early Ser III 4.2 (mid-1979 build date as I recall) where the fuel filter was in the engine bay at the front of the engine. I reckon this was a throwback from the Ser II cars. Anyhow, I wouldn't really expect this on your 1981....but thought it couldn't hurt to just throw it out there.
Old Nov 30, 2014 | 05:11 PM
Fraser Mitchell's Avatar
On my 1980 Series 3 the fuel filter was in the engine compartment right hand (offside) side.
Old Dec 2, 2014 | 04:47 AM
fsmo's Avatar
Well I have had a close look and can't find a decent filter anywhere under the engine bay or elsewhere.
The car was fully reconstructed by Caulfield Jaguar in Melbourne 12 years and looks to me like they removed the bracket for the large/standard filter at the front R side of the spare wheel well. See pic for visual on what is there instead.
I plan to get a bracket and fit it back to original with a new filter.
Sincere thanks to all for your great assistance!
Attached Thumbnails XJ6 S3 - Can't find fuel Filter-81-daimler-xj6-fuel-filter-location.jpg
Old Dec 11, 2014 | 05:22 PM
Stoney85's Avatar
do you have the part number for the Volvo pre filters?
Old Dec 11, 2014 | 09:03 PM
Jose's Avatar
here's a pic showing where mine is in my 1984
wonderwire
Oct 4, 2015 05:41 PM
mat32essex
Oct 3, 2015 04:12 PM
baskervillema
Oct 1, 2015 06:43 PM
dansxj6
Sep 28, 2015 08:02 AM
