Xj6 S3 Ignition (engine) just shuts down
Old Mar 29, 2016 | 05:35 AM
Jag-o-nomic's Avatar
Default An update to an update
Hi All,
Car hasn't stalled once since last posts.
Engine flutters a little at idle, but doesn't drop dramatically like it used to before dying.
This last weekend I got into the boot and checked / cleaned the connectors to the ECU and the 7EM module (DAC2586) which did have some corrosion and oxidation on a couple of points.
Car runs a little better, so I guess what has been said about loose / dirty connections holds true.
I have noticed that on cold start up though, the tacho needle flicks around the dial now.
Now I'm suspecting a voltage spike somewhere, but don't know where to look for that one.
Cheers,
Nigel
Old Mar 29, 2016 | 07:35 AM
Doug's Avatar
Voltage drop, more likely. And, usually, it's the speedo that goes a bit crazy.
Anyhow.....
Clean/tighten all relevant connections. I'd begin with fuses, fuse clips, and the two "+" junctions posts on the firewall.
Rivguy
May 17, 2022 02:54 AM
jmarkitell
Mar 9, 2016 06:27 PM
John Gloyd
Feb 25, 2016 05:13 PM
studentper
Feb 24, 2016 05:08 PM
Desiderata
Feb 23, 2016 08:56 PM
