xj6 series 3 manual 82
Old Nov 27, 2013 | 07:29 AM
ken1's Avatar
Default xj6 series 3 manual 82
hi can anyone help with a problem i have with my xj6, it started running a little rough, now it wont run at all, it starts for a few seconds but then dies, it feels like it runs on the cold start. ive changed fuel filter all hoses in the boot , measured the fuel preasure ( which is ok ) new plugs, check the fuel relay ect
when i move the flap in the afm the pump starts and i can hear fuel running through the system.
i have sparks on all plugs.
????????? help
Old Nov 27, 2013 | 07:37 AM
Doug's Avatar
An easy first step.....
Is the ducting between the AFM and the throttle body secure and leak free?
Old Nov 27, 2013 | 07:45 AM
Welcome to the forum ken1,
I've moved your question from General Tech Help to XJ6 Series I, II & III forum. This is the place to post questions about your model.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Nov 27, 2013 | 08:08 AM
ken1's Avatar
Hi Doug
yes ive checked it. its sitting as it should, ive take the airfilter house off.
Old Nov 27, 2013 | 08:27 AM
Doug's Avatar
This is good but, still, your description of the problem sure sounds like a fuel delivery issue.
Just for the heck of it hot wire the fuel pump just to positively eliminate it. It'll only take a minute.
Remove the fuel pump relay. The socket will have one or two cavities with white/green wires. Run a jumper wire from the battery "+" post (or any constant 12v source) to both of the white/green wires. One or the other will make the pump run constantly.
Now start the engine and see if anything changes
Old Nov 28, 2013 | 03:53 AM
ken1's Avatar
hi Doug thanks.
done that, its the same, if i disconect the afm it runs on tickover but i cant gas it , it just die,s im getting fuel to the rail at 28 psi. i know i have a fault on the return valves to the tanks to, it returns the feul to the wrong tank.
Old Nov 28, 2013 | 03:56 AM
ken1's Avatar
it seems to be a simular problem that docppo had last march. but he didnt post the fix lol
https://www.jaguarforums.com/forum/x...nnected-91805/
Old Nov 28, 2013 | 04:31 AM
It's been many years since I ran Series I and Series II and Series III was one of the few models I missed owning but .....
....... does Series III have the same AED (Automatic Enrichment Device) as the earlier models? If it does, I had exactly the symptoms you describe with a Series II 4.2 which turned out to be a failed AED.
If Series III doesn't have this, just ignore me!
Old Nov 28, 2013 | 05:08 AM
Doug's Avatar
This is really weird.
I'll do some mulling.
Old Nov 28, 2013 | 05:18 AM
Doug's Avatar
A Ser III with the 3.4 engine, which runs on carburettors, has an AED, yes.
The 4.2 fuel injected cars have a cold start injector that sprays a extra slug of raw fuel into the inlet manifold if the engine is cold. It operates only for a few seconds and only if the starter is engaged. To prevent flooding a thermotime switch defeats the cold start injector if the starter is operated for more than a few seconds or if the engine is warm.
Old Nov 28, 2013 | 05:21 AM
Doug's Avatar
Unplug the cold start injector. Any change?
Do you have voltage to the 6 regular injectors? Are they ticking?
Old Nov 28, 2013 | 09:01 AM
ken1's Avatar
it runs on tick over if i disconnect the air flow meter.
Old Nov 28, 2013 | 09:04 AM
Doug's Avatar
Oh, yeah, I forgot that part.
So obviously the injectors are functioning, at least with the AFM disconnected
Still mulling
Old Dec 9, 2013 | 10:51 AM
ken1's Avatar
ive just striped the injects out, to discover a brown sludge clogging the fuel intake pipes of each injector, ive got a gut feeling this is the problem. When i changed the fuel filter it did,nt show any rust partickles as you normally get with a rusty fuel system, so i think its been changed before i think.well its changed now. So ive left the injectors in to get sonikly cleaned.
The car has been sat in a barn in Italy for 22 yrs, im guessing the tanks may need cleaning out properly and coating on the inside.
Old Dec 16, 2013 | 04:02 AM
ken1's Avatar
runs like a dream. thanks for everyones advice.
time to fit a motor heater in the motor cooling system.
pnwrs2000
Jan 15, 2018 07:20 PM
ahunt4
Sep 14, 2015 08:17 PM
Charlene n John
Sep 14, 2015 12:01 AM
jagent
Sep 7, 2015 05:00 PM
