xj6 trunk will not open with key, any other way?
Greetings,
I just bought a 1986 XJ6 and I cannot get into the trunk. Battery was dead when I got the car, I replaced it and the car runs good. The trunk key turns to the left in the lock a few degrees but the trunk does not open. Is there a solenoid in there to open the trunk or is it mechanical? Is there any other way to get it open without the key that is not destructive like a cable or switch in the cabin?
Try going in through the rear seat(?) I'll defer to more knowledgeable folks, but that'd be my first thought. The way the squab (back) of the seat is held in might prohibit that option, though.
Greetings,
no access through the rear firewall behind the rear seat, it's solid except for the sunrood motor hole.
the holes Bob is referring to are the upper and lower license plate holes on the right side, through which you can see the vertical linkage Rod after you remove the license plate.
you can use needlenose pliers to grab the rod and pull it up to open the trunk lid.
Wolfy
May 28, 2024 08:06 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
Nov 23, 2015 01:56 PM
FS[NorthEast]: HOT Black/Black '07 S-Type R w/55k miles for sale!
08Z06
Oct 24, 2015 05:46 PM
