XJC rear window fuses?
Old May 24, 2014 | 11:33 PM
smgdata's Avatar
Default XJC rear window fuses?
I can't for the life of me find. the fuse if any or an inline fuse for the rear windows.
I do know they work I jumped them with a wire that had power.
but this is issue is eluding me.
Old May 25, 2014 | 05:13 AM
Not aware of a fuse in the S2 window circuits at all.
There is a thermal overload unit (possibly a fuse to some) that will kill ALL windows, not just one or a group of rears etc.
The wiring "thru" the switch packs is IFFY at best, and if its crossed up/messed up, the power dont "flow" from the master (drivers window) thru to the next in line (Pass front), then thru to the next etc etc, and if the "master" is being used, the rest are isolated.
Also those S2 window switches are a PAIN, even when new.
Somewhere here, there will be a wiring schematics, and when I find it, work interrupts these adventures, I will scan and post it. If not I will hand draw it from memory, HAHAHA.
Old May 25, 2014 | 11:54 AM
smgdata's Avatar
thanks grant that would be great!!
Old May 25, 2014 | 01:03 PM
icsamerica's Avatar
The windows switches in the front console and the ones in the rear on the tunnel need to be wired and operating properly for either to work. A fault in either will render the other inoperable. I could never get them to operate consistently on my series 2 coupe and adapted the wiring and switches from a series 3 and now they work consistently.
99xk8guy
Sep 29, 2025 10:51 PM
H20boy
Dec 24, 2024 03:23 PM
99xk8guy
May 28, 2024 09:36 PM
GordoCatCar
Jan 2, 2017 01:10 PM
motorhead69
Sep 9, 2015 10:04 AM
