14mm or 16mm inner tie rods?
Old Jan 23, 2018 | 02:10 PM
JameyXJ6's Avatar
Default 14mm or 16mm inner tie rods?
My 1983 xjs needs a new rack and pinion.
The parts stores are listing two different applications, one with 14mm inner tie rods and another with 16mm inner tie rods?
Is one more common than the other? Maybe for a specific package or option?
Any easy way to tell which one I’ve got? Or will it make any difference as long as the outer tie rods are the same?
Old Jan 23, 2018 | 02:54 PM
baxtor's Avatar
It won't matter so long as you go with complete unit with outer ball joints.
parts list only seems to list the one inner tie rod JLM409 but l do know there was a change to outer rod joints at some time.
Old Jan 23, 2018 | 03:48 PM
JameyXJ6's Avatar
Perfect! That’s what I was hoping to hear! I was just concerned that there was a significant difference between the two and therefore I would have to determine which size I had and replace it with the same size.
nickxj6
Mar 18, 2015 05:34 PM
vincent661983
Sep 22, 2013 10:24 AM
Ziggy
Apr 4, 2013 09:40 AM
daboss085
Nov 1, 2012 05:13 PM
rudelover2
Aug 6, 2011 04:30 AM
