1980 XJS and 1976 XJ6 suspension are the same?
Old Mar 1, 2020 | 07:47 PM
Bez74's Avatar
Default 1980 XJS and 1976 XJ6 suspension are the same?
There is a 4.2 1976 XJ6 for sale that I am thinking about purchasing. for spares for my XJS.
When i say "spares", it looks too good to scrape or part out, and with the asking price being what it is - it could be another project for me.
So my question is
Is the rear suspension cage and the front suspension system (including steering rack) the same as my 1980 XJS. That is - can I pull the rear cage out of the XJ6 - recondition everything and then place it in my XJS. Just to keep off road timing to a minimal. I then recondition the XJS cage and put it back into the XJ6
My XJS speedo is cable driven - is the 1976 XJ6 speedo also cable driven
Hope my question makes sense
Steve
Old Mar 2, 2020 | 12:05 AM
Jagboi64's Avatar
Yes, they should be the same. Only difference might be the presence or absence of a rear anti roll bar, as Jaguar added and deleted them over the years. The differential ratios may be different too, depending on the market. I don't know what was standard in Australia. My guess is a 1976 will be a 3.31 ratio.
Old Mar 2, 2020 | 12:59 AM
Greg in France's Avatar
The front stub axle and wheel bearings are not identical, I believe, but the XJS ones will fit the XJ6 uprights. I have a pretty firm idea that the XJS stub axles were beefed up in the late 1970s.
Old Mar 2, 2020 | 01:15 AM
Bez74's Avatar
Thank you Jagboi an Greg -
Finding it very hard to say no at this point.
The different ratio of the diff is even more appealing
Can't get away from work until Saturday week, so doing my research. I keep going back to the advert and I like it more each time. Same thing happened when I first saw my XJS
Steve
Old Mar 2, 2020 | 02:29 AM
Agree, same same.
The wheel bearings front from 1976 to and including X300 are the same Part Numbers.
XJ6 4.2 Aussie is probably 3.07. The XJS would I thing?? be 3.31, diff ratios.
S2 cars was the start of metric pipes etc for brakes, so just be aware there may be oddities here and there. Nothing a few beers wont sort.
sidescrollin
Aug 16, 2018 08:23 PM
JessN16
Apr 27, 2017 08:01 AM
Roamer
Jan 28, 2016 08:30 AM
Dexter Adams
Oct 12, 2013 02:53 PM
Dec 28, 2006 09:30 PM
