1987 Jaguar - top switch
Old Jun 22, 2009 | 03:26 PM
manderson10's Avatar
The parking brake has to be engaged to get the top to work. I had a similar problem with my 1990 and tried several things then I was told by a member of this forum about the parking brake and I felt really stupid when I engaged the parking brake and it worked fine. Just a thought.
Old Jun 25, 2009 | 01:51 AM
Sarc's Avatar
Default or.....
(Assuming you have your parking brake on)
It is often the switch thats gone wonky. I had a similar problem with one of my window switches, ie it would drive the window up but not down again.
It's easy to remove the switch from the console, just pry it out gently, then unplug the wiring harness.
The quick and dirty way to clean it is to squirt WD40 everywhere, but its fairly simple to take the switch apart and clean the contacts. I just rubbed mine with light emery paper to make the contacts shiny again. (They had gotten quite a lot of carbon build up on them)
1100me
Aug 27, 2020 11:37 PM
jdzubas
Oct 4, 2015 09:14 AM
thedugger1
Sep 24, 2015 05:32 PM
Jandreu
Aug 29, 2015 07:31 PM
Marque
Aug 27, 2015 11:53 AM
