1988 electrical question
Old Sep 17, 2023 | 05:22 PM
AZDoug's Avatar
Default 1988 electrical question
Is there any constant parasitic draw from the ECU or anything else on these cars that would suggest adding a simple battery disconnect switch?
My '16 Z06 is always sucking power when off, doing "something", so it needs to be on a battery tender or have the battery disconnected if it isn't going to be regularly driven.
Thanks,
Doug
Old Sep 17, 2023 | 05:40 PM
Mac Allan's Avatar
Factory alarm system, if you have it, is a parasitic draw that requires either a battery tender or a cut off switch. The one issue with a cut-off is if you have factory stereo that requires a code when reconnected to power.
Old Sep 17, 2023 | 07:48 PM
jal1234's Avatar
Thanks,
Doug
The only draws in an 88 is the keep alive of the radio and a very small draw from the trip computer. That's assuming everything in the car is original and in good shape with no add-on accessories. I have had a capacitor in the door lock solenoid go bad and start a parasitic draw.
I recommend a cheap battery tender. I've used one of these on several cars. Start with a charged battery, and it'll maintain it without overcharging.
https://hftools.com/app59000
Jon
DanoldKong
Jul 10, 2023 11:24 PM
Pistnbroke
May 14, 2021 09:08 AM
gbentz
Sep 26, 2017 09:41 AM
sg18438
Mar 10, 2016 07:25 AM
mojorising
Oct 26, 2010 09:52 AM
