1988 window motors
Old Feb 6, 2013 | 11:21 PM
JT-1988-XJSC's Avatar
Default 1988 window motors
After being stored for several years, both window motors are having problems. Actually it is the plastic gears in the motor assembly that didn't like the Texas heat. I have tried ordering new ones, but all I can find are "8 tooth" motors. Mine have "10 teeth" in the motor drive gear. I don't want to replace the regulators too. Any idea if the 10 tooth motors are still available, or possible to rebuild the ones I have?
1988 XJSC
Thanks,
JT
Old Feb 6, 2013 | 11:45 PM
Doug's Avatar
Are your motors essentially cylindrical with a flat surface on opposite sides? if so, I was able to get parts store replacements. The gear drives didn't match but i was able to swap my gear drives onto the new motors. I'll try to find a part number for you
Old Feb 6, 2013 | 11:58 PM
Doug's Avatar
Here's what I used, a Cardone 42-130
Remanufactured Window Lift Motor by Cardone (part#42-130) / Lifts, Latches & Handles
Only take 5 minutes to swap the gear drives
My memory is foggy on the 2 or 3 supercessions of window motors so if your's is a different style I'm not sure what will work without getting the matching regulator. But...if you get a cooperative parts guy who is willing to open some boxes, you might get lucky and find something close enough to work
On other makes of cars besides Jaguar I've swapped gear drives to make things work so don't give up without a little investigating and mix-n-matching :-)
Old Feb 7, 2013 | 06:38 PM
Thanks Doug.
The motors are like the Cardone #42-130 (I'm not sure about the worm gear, but it may be the same.) It meshes with a gear about 2 3/8" in diameter & the "output" gear is about 3/4" diameter (10 teeth). The motor is OK, but the mating (2 3/8") gear teeth got deformed by the pressure of the worm gear over time. The 3 mounting bolts are in a different position than the Cardone unit.
I need to replace at least the gear drive instead of the motor. Thanks for the links. I'll start looking for "functional replacements". I was hoping that maybe just an earlier or later model part would be the correct one.
Old Feb 7, 2013 | 09:12 PM
Mish_Mish's Avatar
I had internal gear stripped by the motor's drive axle. I opened gear housing, cleaned all fossilized grease and flipped driven gear, so motor would drive the other side of it. All I had to do is drill 3 holes on side of the large gear, so it could be flipped. Works like new, along with new channel guides.
Old Feb 8, 2013 | 11:03 AM
xjrguy's Avatar
You guy's are AWESOME!
I come up with numerous answers around here, but this is the kind of stuff I would NEVER have figgered out. Proves you are never to old to learn stuff.
Keep up the good work!
Old Feb 9, 2013 | 12:26 PM
Default 98% sure this is the fix I needed!
Mish,
What a great fix! I'm doing it this weekend & taking some pictures. It isn't that obvious that you can flip the gear, but you can. I'm really jealous that I didn't even think to try this when I saw the rubber cushion built into the gear. Once it's reinstalled & working I'll post the pic's. The regulator is working smoothly on the bench now!.
Thanks a Million!
JT
Old Feb 9, 2013 | 02:40 PM
warrjon's Avatar
Do you mean the Baily channel the windows run in???? if so where did you get it. I have been waiting 6 months for my Jag guy to find 2.
Old Feb 9, 2013 | 04:23 PM
Default Gear Flip Confirmed
I just reinstalled the motor with the flipped gear & it works great. The description my Mish was good. I also had to plane off a raised area on one side. Pretty self-explanatory. I attached some photos for reference.
You can see the damaged area in the gear.
Thanks again!
Attached Thumbnails 1988 window motors-last-import-03.jpg   1988 window motors-last-import-06.jpg   1988 window motors-last-import-09.jpg   1988 window motors-last-import-10.jpg
Old Feb 9, 2013 | 10:04 PM
Mish_Mish's Avatar
This is exactly what I did, but forgot to take pics. One more thing, remove spacers on one side of the gear and put on another, this way you will move driving shaft all the way onto the fresh teeth of your large gear.
Glad I could help...
Old Feb 9, 2013 | 10:05 PM
Mish_Mish's Avatar
Welshent.com - $44, also saw them on ebay for around the same.
Old Feb 9, 2013 | 10:07 PM
Mish_Mish's Avatar
NOTE TO ALL Y'ALL, use compressed air to blow off window tracks rubber very well. Sand particles that accumulate in those over time cause extra friction and premature window transport wear.
Old Dec 23, 2014 | 11:01 AM
rolandyoug's Avatar
Originally Posted by JT-1988-XJSC
Mish,
Thanks a Million!
JT
JT how did you remove the drive gear assembly so that the plastic gear could be flipped? it's not obvious.
rolanyoug
1988 jag xjs
mbergen
Oct 23, 2019 10:26 PM
mikimogo
Sep 22, 2015 08:09 PM
somoflange
Sep 16, 2015 10:16 AM
mikimogo
Sep 14, 2015 08:34 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
