1988 XJ-S charging issue
Old Jul 12, 2009 | 10:43 AM
RandallCB's Avatar
Default 1988 XJ-S charging issue
Hey all before going through the removal of the Alternator I wanted to ask if there is any other reason that I would not be getting enough charge. Normal would run between 12 to 13 amps charging, although now bairly pushing 8 to 9, which is not enough to keep battery charged. I have checked and now replaced the belts. Checked all wires no bad wires.
Can you give me any other hints??? Change to new Alternator???
Again thanks again in advance for all your help...
Randy
Old Jul 12, 2009 | 12:40 PM
Thermo's Avatar
Veteran: Navy
Randall, if you have an externally charged field alternator, then if that wire is not getting sufficient power, it can cause what you are seeing. But, since you are only seeing reduced charging ability, odds are that wire is fine and you simply have an alternator that is starting to go.
if you are not sure if you have an internally or externally fed alternator, it is easy to figure out. If you have only a single wire coming off of the alternator, then it is internally fed. If you have 2 or more wires, then it is externally fed.
Old Jul 12, 2009 | 12:46 PM
RandallCB's Avatar
It has one wire... would you recommend replace?
Forcedair1
Sep 8, 2025 01:57 PM
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
mbergen
Oct 23, 2019 10:26 PM
jaguarbill
Sep 5, 2015 11:43 AM
