1989 XJS ABS..no fluid to LF from master cyl
Old Feb 7, 2013 | 03:59 PM
wesmc2's Avatar
Default 1989 XJS ABS..no fluid to LF from master cyl
So I threw up a post a bit ago about this issue...three wheels have brakes. LF does not. I am just getting back on it.
If I disconnect the hardline at the master cylinder there is no fluid coming out. Any ideas on diagnosis? I don't want to buy a used master/abs unit just to install and find it is the computer, or vice versa. Seems more likely that a soleniod is being told to stay closed. I searched for a pinout of the ABS connector but came up empty.
Old Feb 7, 2013 | 08:26 PM
jagjerk's Avatar
Unhappy Front brake problem.
Have the exact same problem with my '89.Hope to remove the pressure differential this weekend.Shop manual say's not servicable.We will see about that.Will let you know if i find a solution.
Old Feb 8, 2013 | 10:54 AM
xjrguy's Avatar
See the post from another thread below. The Hydraulic Valve Block could easily explain your trouble as well.
https://www.jaguarforums.com/forum/x...73/#post672494
Good luck!
Old Feb 11, 2013 | 03:46 PM
wesmc2's Avatar
XJRguy- thanks for the info..
Jagjerk-Please do let me know what you find. I am doing some more searching and I'll let you know what I find
Old Jan 25, 2014 | 01:02 PM
bul1111's Avatar
wow i have same problem do you find some solution ????? , i screw master cylinder pipes and noting happen
;[[[[[[[[[[[[[[ very very upset from this xjs
Old Jan 31, 2014 | 10:42 PM
jagjerk's Avatar
Default XJS brakes
Sorry to hear you to are having problems with the hydraulics on your car. I think I was lucky to solve mine. I got away with flushing the brakes several times on the the calipers I could bleed. Eventually I got fluid out of the left front.Also disconnect hose at hard line to check for pressure. Hose could be bad. The system appears to be very sensitive to dirt. Also drive at least several times a month,getting car up to running temperature.If I don't drive mine every month it will pull to one side when braking. Good luck.
vinny jones
Apr 28, 2021 08:14 AM
vinny jones
Oct 5, 2015 07:20 AM
UalCapt
Sep 14, 2015 01:42 AM
Greg Reed
Sep 11, 2015 08:41 PM
1100me
Sep 7, 2015 06:26 AM
