1990 Window Lift Switches
Old May 19, 2020 | 07:17 PM
mikebaker3's Avatar
Default 1990 Window Lift Switches
Replacement Window Lift Switches DAC7526 and DAC7527 seem to be made with too soft a plastic for the switch housing that lets the rocker come loose. Does anyone make a switch more like the original switches that will stay together for more than a few weeks? Every time I replace one, the rocker comes loose at one side or the other.
Old May 19, 2020 | 07:23 PM
Jagboi64's Avatar
Are you buying them from Jaguar, or the Uro brand? The difference is Jaguar has a metal retaining clip, the Uro is plastic. Uro is junk, and I've not had trouble with the original Jaguar switches. There is a reason they cost more...
https://parts.jaguarlandroverclassic...ft-switch.html
Old May 19, 2020 | 07:35 PM
mikebaker3's Avatar
JagBoi64 I have gotten switches previously from Welsh Enterprises and also from XKs Unlimited (before Moss bought them out) and had the problem with both.
I will order a set from Jag and post an update.
Old May 19, 2020 | 08:31 PM
Jagboi64's Avatar
I replaced all my switches with genuine ones, and they have been trouble free for 3 years now.
Old Jun 10, 2020 | 09:08 PM
mikebaker3's Avatar
Default Side by Side switch comparison
New switches arrived early last week. Here is a photo of the OEM switch made by TRW on the right and the aftermarket switch on the left. The TRW switch has metal clips to hold it in place, whereas the aftermarket switches that do not last have a plastic clip. It was $140 (shipping included) for a pair of the switches. The OEM 7526 showing the window picture facing the opposite way were not available, so I bought two with the symbol facing the same way.
DAC 7526 is an aftermarket switch, whereas the OEM DAC 7527 made by TRW is on the right
10 XF Premium
Oct 11, 2018 11:03 AM
Dymaxxion
Nov 4, 2015 07:59 AM
dickc
Jul 23, 2014 02:16 AM
Jsedita74
22
Jun 14, 2011 07:09 PM
johnpiero
Jan 24, 2010 11:38 PM
