1990 XJS Firewall Vacuum Question
Old Nov 13, 2013 | 01:01 PM
petermparis's Avatar
Default 1990 XJS Firewall Vacuum Question
I have a 1990 XJS and need help with understanding the
climate control vacuum routing.
I have three vacuum hoses coming off the passenger side
firewall into the engine compartment. Two black hoses, one
with a check valve on it and the third hose is a red.
All the vacuum charts I've seen for the car show two hoses of
f the passenger side firewall - one for the climate control
vacuum off the back of the intake manifold on the A side and
the other hose going to the heater control valve.
Could anyone shed light on where each of these three hoses
go-
1. red hose
2. black hose with check valve
3. plain black hose
Thanks,
Peter
Old Nov 13, 2013 | 09:09 PM
xjrguy's Avatar
1. red hose
small red plastic vacuum hose goes from rear of RH intake manifold to the Marelli Ignition ECU at the base of the RH "A" pillar.
black side of the check valve [should be black hose w/white trace] goes to vacuum tee that splits and goes to the RH manifold and to the round, bluish full load vacuum switch at top rear of intake manifold.
3. plain black hose
probably the hose to the heater water valve at center of firewall
Cheers,
toronadomike
Jan 22, 2026 10:13 PM
clubairth1
30
Sep 3, 2025 04:38 PM
Bcrary3
Feb 21, 2023 04:29 AM
cissdm
May 3, 2016 06:02 AM
Saturbo
Sep 8, 2015 07:35 PM
