1991 xjs v-12 engine missfire
Old Dec 23, 2008 | 07:59 PM
schroeterkurt's Avatar
Default 1991 xjs v-12 engine missfire
I have a 1991 xjs. The engine is not firing on all the cylinders on the passenger side. I can smell gas but i don't see any leaks. the passenger side exhaust is much cooler than the driver side and erratic. This has happened a few timesin the past but only for a few minutes. It seems to be permanent now. Any help will be appreciated. Thanks, Kurt
Old Dec 23, 2008 | 08:10 PM
Doug's Avatar
Default RE: 1991 xjs v-12 engine missfire
ORIGINAL: schroeterkurt
You have a failure of the Marelli ignition, most likely the dual plane distributor cap and rotor, but check the coils and modules, too.
If there is any doubt as to when the plugs and wires have been changed, replace them while your at it. Gap plugs to .025"...no one iota more.
Don't drive the car !! The converter on the dead bank will fill will fuel, overheat, and possibly cause a fire.
Some guys have converted to Lucas CEI ignition which is a good system and doesn't suffer this particular type of failure.
Old Dec 30, 2008 | 05:04 PM
Doug, sorry for the delay. Thanks for your help, any other helpful tips would be apreceated. Hope you have a joyful new years. Thanks, Kurt
Forcedair1
Sep 8, 2025 01:57 PM
cissdm
May 3, 2016 06:02 AM
d a
Sep 3, 2015 02:34 AM
OkieTim
Sep 2, 2015 12:48 PM
XJsc-guy
Sep 2, 2015 11:43 AM
