1993 4.0 Cruise Control Diagram
Old Apr 13, 2020 | 03:41 PM
petemohr's Avatar
Default 1993 4.0 Cruise Control Diagram
Is the Cruise control System documented anywhere? I have the Service Manual and it has an electrical diagram but no explanation as to how it is supposed to work. The vacuum lines to my pump have been disconnected (don't ask) and one is missing so I need a diagram to hook them back up. It would also be nice to have some doc. concerning how the system operates. .I never use it so I'm thinking about just removing the pump, actuator, dump valve and vacuum lines. I assume something will have to be capped off to prevent vacuum leaks. Any help would be greatly appreciated.
Old Apr 14, 2020 | 09:00 AM
petemohr's Avatar
So, the vacuum lines are pretty simple. No need to plug anything.
But I'd still like to find some details on how the system operates.
Old Apr 18, 2020 | 09:30 AM
petemohr's Avatar
Default Diagram
No one seems to care but here's the diagram I found in the X300 forum.
Old Apr 18, 2020 | 10:28 AM
Tonyj's Avatar
Not sure what you mean by 'how system operates'? There are electronics that control the vacuum system.
Do you want info on the electronics and/or vacuum system?Do you want to know how to engage cruise control?
The electronic system can be worked out from the electrical diagrams - connections between control module, gear shift, brake pedal, Speed control switch, Reset switch and vacuum system.
Vacuum system as per your diagram - pump, 1, causes bellows, 3, to move and pull the throttle open a fixed amount (simply put).
Tony
Old Apr 19, 2020 | 07:15 AM
petemohr's Avatar
Thanks for the reply. Yeah, now that I've looked at it, it is pretty simple. I'm still surprised that there isn't a diagram like the one from the X300 or any writeup on the system anywhere in the XJS doc.
XJ12C_Driver
Apr 2, 2020 06:09 PM
cadfael_tex
Apr 23, 2019 09:27 PM
Mark Murphy
Jan 9, 2018 12:52 PM
superchargedtr6
Jun 30, 2014 09:05 PM
RagJag
May 23, 2014 11:56 AM
