1993 XJS Immobilizer Problem
Old Aug 30, 2018 | 04:42 PM
gthawk1's Avatar
Default 1993 XJS Immobilizer Problem
Hi. I have a 1989 XJS V12. I'm thinking of buying a 1993 XJS, 6 cylinder, 90K convertible. The owner states that it will not start, the immobilizer is preventing it from starting. He said he took it to a Jaguar dealer, the tech tried to reset the immobilizer module both with the fob, and, with the reset procedure. Neither worked. Is there a way to fix this? Can I buy a used module and install it? Could the problem just be the inertia switch? Haha. Any ideas?
Old Aug 30, 2018 | 06:12 PM
sidescrollin's Avatar
Is that a factory immobilizer?
The inertia switch would be a really straight forward check, but the diagnosis overall will be a little more complicated. Check voltage at the ignition switch, starter relay, etc. I would do the regular no-start checks and take the PO's diagnosis with a grain of salt. I'm not saying not to look at the immobilizer, just that the regular no-start stuff doesn't take up much time to double-check.
Old Aug 30, 2018 | 11:49 PM
Ezrider's Avatar
i think the factory immobilizer is lucas electric products.
Old Aug 31, 2018 | 07:12 AM
malc4d's Avatar
A US '93 is a1992 build. The alarm module is in the right side of the trunk behind the rear light. It has a big white multiplug that connects it to the car.Try unplugging that and see if it will start. When you replug it the alarm will make a noise,5 of them. After each sound press an alarm fob and if working properly the alarm will beep back. This must be done 5 times, even if you only have 1 fob.
Maxville
Aug 1, 2022 10:14 PM
Josasaja911
Jan 26, 2016 06:02 PM
cobrawet2
Oct 20, 2014 02:31 PM
aussie_ser3
XJ40 ( XJ81 )
May 9, 2014 05:46 AM
Mr-Happy
Mar 28, 2014 09:44 PM
