1994 Jaguar xjs 4.0 intermittent no crank condition
Old Mar 5, 2023 | 12:02 PM
jagowner659's Avatar
Default 1994 Jaguar xjs 4.0 intermittent no crank condition
Hello all I have a 1994 jaguar xjs 4.0 convertible.
lately it’s been doing this thing where the car randomly won’t crank. every time it’s happened I’ve had to leave it and use another vehicle to get somewhere and inevitably when I return to it it starts cranking and runs perfectly. I was hoping someone might have some kind of idea as to where to start in regards to troubleshooting. I’ve also tried starting in neutral as well as charging the battery and checking the starter relay. I’m pretty inexperienced so any advice is appreciated
Old Mar 5, 2023 | 02:50 PM
Vee's Avatar
Vee
When was the last time you replaced the camshaft position sensor.
Common problem.
Common symptom.
Easy repair. You can do this yourself.
Old Jul 27, 2023 | 08:24 PM
orgullodemexico's Avatar
Common problem.
Common symptom.
I've never replaced that. I will put it on the to do list.
Rchuda
Feb 28, 2023 07:05 PM
93xjs6cyl
Oct 23, 2022 12:47 PM
tromper
Aug 10, 2021 05:16 PM
dave1994
Jun 1, 2017 04:59 PM
