1994 Jaguar XJS Ignition Issue?
Old Nov 12, 2010 | 07:55 PM
Brian Felts's Avatar
I had a problem similar to that in my 95 xj6. I kept finding my trunk was unlocked or left ajar. Make sure everything is closed and use the key to lock the doors from the drivers side. Do you get a chirp from the security system?
My little one liked to hit the jag on the back and open the trunk. When I unlocked the doors it activated the kill system.
Brian Felts
Old Nov 12, 2010 | 09:57 PM
motorcarman's Avatar
The BLUE relays in that vintage Jaguar were Not very reliable. I replaced alot of relays for dead XJ6 and XJ-S. There are several that are critical like the ECM and fuel pump etc. There are some that are LOAD relays that power major circuits. You might also have a faulty ignition switch so pull the column cowl and back probe the switch IN/OUT circuits. Get an electrical guide so you know what is power and what is earth!!!
bob gauff
1100me
Aug 27, 2020 11:37 PM
DrScientist
Dec 9, 2015 07:36 PM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
1100me
Aug 28, 2015 09:48 PM
