1994 Starting problem
Old Mar 25, 2015 | 05:26 PM
mannymux's Avatar
Default 1994 Starting problem
Guys, I just purchased a 94 XJS today. I noticed that after you run the car, if you turn it off and then try to turn it on again, it won't turn over. I have to turn the key and then start it again and it starts on the 2nd try. What might that be? Thanks
Old Mar 25, 2015 | 10:39 PM
scarbro2011's Avatar
I remember a tip about the 90/91 models saying that if you switch the ignition on/off
too quickly and there was a weak battery or bad battery connection,
the ecu would generate a false code "69" and this would cause a delayed
PARK/Neutral status.
The ecu will not allow a start if there is no Park/Neutral Status=True.
Which means the car will not start until a delay has timed out. 30 -60 secs?
Maybe this is the same for the 94 model?
Anyway it may mean that you have a weak battery or bad battery connections.
Battery =4 years or older = time to get another battery.
P O R (Press On Regardless)
Old Mar 26, 2015 | 07:03 AM
mannymux's Avatar
Thx Bud. The owner gave me that code. I guess that's what it is.
Old Mar 26, 2015 | 08:04 PM
I found the actual reference in the Jag DTC reference (18-39) and it is for the 94 XJS 4.oL! See the download section in the "Stickies" section.
JarodL
Mar 7, 2024 01:39 AM
alpecsa
Sep 7, 2015 11:55 AM
tberg
Sep 7, 2015 07:32 AM
David Thompson
Sep 3, 2015 07:48 PM
laserguy
Sep 3, 2015 02:02 PM
