1994 XJS 4.0 transmission help please!!
Old Sep 22, 2018 | 09:54 AM
romeo8426's Avatar
Angry 1994 XJS 4.0 transmission help please!!
hello gents, sorry to bother you. i have a 1994 xjs 4.0 model with only 51,000 miles, yesterday it seems like its stuck in limp mode, it will not go pass 35mph. trans fluid level is good. does into drive instantly and reverse. any advice or experience with this? looking forward to some help.
thanks
Old Sep 22, 2018 | 01:01 PM
Vtjaguarlover's Avatar
My XJS's are V12's so there experience here won't help, but one of my X300's had this problem. It had the AJ16 engine which in my case was irrelevant but may have something to do with your problem. In my case the car had 160,000 miles on it and the transmission fluid was old and slightly burnt smelling. I changed my fluid and filter which was plugged up and resolved my problem. While I was researching the problem it appeared that others who had this problem said it was a throttle body issue. If you would like to do a little more research yourself, look in the X300 forums as they have the similar engine/ transmission issues.
Old Sep 22, 2018 | 10:58 PM
Ezrider's Avatar
mine used to do that every now and then as well. if i would tap on the trans relay under the hood a few times and turn the key on and off it would go away.
cbryantjr85
Oct 21, 2016 03:46 PM
roadsterboyjeff
XJ40 ( XJ81 )
Jul 4, 2015 02:47 PM
rama1200
May 18, 2015 07:29 PM
sweetmelissa
XJ40 ( XJ81 )
Aug 31, 2009 10:34 AM
