1994 XJS Convertible Drivers Window
Old Nov 3, 2024 | 05:09 PM
Cregan's Avatar
Default 1994 XJS Convertible Drivers Window
Hi all,
I recently acquired my 1994 4.0L convertible XJS and the drivers window stopped functioning (lucky for me in the up position)
I cant find any associated fuse in the diagrams... it just rained for the first time last night which might have something to do with this... any idea for a fix?
This is my first post here so thanks so anything
-Cregan
Old Nov 3, 2024 | 05:42 PM
ptjs1's Avatar
Cregan,
Start with the switch. Nearly always the problem. Wiggle the rocker a little bit carefully and see if that resolve sit.. If not, you need to disconnect the wire plug and try swapping it with the passenger switch. You'll need to lift the skislope. Don't try and remove the switch from the bezel from the top. You'll break the plastic tangs,
Paul
Old Nov 3, 2024 | 08:05 PM
Cregan's Avatar
Well thats good news then, what is the skislope?
Thanks again,
-Cregan
Old Nov 3, 2024 | 10:19 PM
Vee's Avatar
Vee
Its the curved wood piece where your gear selector, lighter, ashtrays and cruise control and window switches all sit.
Zarathushtra
Nov 5, 2023 12:59 PM
Mbower1967
Oct 22, 2023 01:15 PM
JayJagJay
May 20, 2021 06:32 AM
Jaglady96
Jul 17, 2019 07:22 PM
NCJagman
Oct 12, 2017 08:23 AM
