1994 XJS V12 braking issue
Old Nov 26, 2013 | 08:17 PM
alabbasi's Avatar
Default 1994 XJS V12 braking issue
I posted to a thread earlier but my solution did not seem to work. On my 1994 XJS V12. The booster did not work and I'm getting weak braking in the rear wheels , although I can lock the front wheels up if I stomp really hard on the pedal.
I replaced the accumulator which did not help. Here's what's interesting;
When I removed the accumulator, I was expecting brake fluid to spray all over the place but this did not happen, even though I did not pump the pedal while the motor was off.
Furthermore, there's a rubber line from the abs pump to the firewall which I assumed initially was a vacuum line or a fluid line. However aside from a couple of droplets, there was no brake fluid and no vacuum.
Any ideas?
Old Nov 27, 2013 | 07:07 AM
xjsv12's Avatar
Bleeding
Old Nov 27, 2013 | 07:09 AM
xjsv12's Avatar
bleeding
Old Nov 27, 2013 | 09:52 PM
alabbasi's Avatar
Oh b*ll*x, I managed to break the little plastic elbow on the rubber hose that goes to the ABS pump. Anyone know the part #. I can't seem to find it anywhere.
Old Nov 29, 2013 | 09:05 AM
xjsv12's Avatar
12 + Hose kit
+ To VIN (198334)
+ high pressure
JLM1462 £56.43 Add to cart
+ low pressure
+ LHD
JLM1471 Contact Us
+ RHD
JLM1470 £19.99 Add to cart
Old Nov 29, 2013 | 10:06 AM
alabbasi's Avatar
Thank you
JarodL
Mar 7, 2024 01:39 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
XJsc-guy
Nov 23, 2015 01:56 PM
Raul Lara
Sep 14, 2015 07:31 PM
XJsc-guy
Sep 2, 2015 11:43 AM
