1995 Jaguar XJS Automatic Transmission Shifter is stuck... Help!
Old Aug 10, 2023 | 08:59 PM
FilmDirector's Avatar
Default 1995 Jaguar XJS Automatic Transmission Shifter is stuck... Help!
My 1995 6 cylinder Jaguar XJS Automatic Transmission Shifter was not shifting and stuck in park after I bought it recently and went to pick it up. When I test drove it, that wasn't a problem.
The car was towed to a shop. The mechanic said he disconnected the cable on the transmission side. He said the cable is binding and the transmission lever is hard to turn. He was able to put the transmission in neutral. He thinks that the linkage will free up after the car is driven a bit. For now he says the cable is frozen inside.
He doesn't want to work on the car because he's not familiar with the car and works mostly on German cars and doesn't want to create any more problems.
So i will have to tow it to another mechanic who will hopefully be better able to fix it. I would greatly appreciate whatever advice any of you can give about the problem and how to resolve it. Thanks. 👍
Old Aug 11, 2023 | 02:01 AM
Keesh's Avatar
It is a German gearbox from ZF in an XJS
Old Aug 11, 2023 | 03:27 AM
Thanks for your reply. So what advice to fix the problem?
Old Aug 11, 2023 | 04:22 AM
ptjs1's Avatar
FilmDirector,
I presume you don't mean that you actually towed the car on its wheels, at least not without disconnecting the propshaft?
A binding cable sounds quite unusual. At the risk of questioning your mechanic did he check the operation of the rotary switch and also the interlock inhibitor which are far more common problem areas when there is a problem with selector operation on these late XJSs?
Good luck
Paul
Old Aug 11, 2023 | 10:50 AM
Softball60's Avatar
Question,
when you starting your car and you press the brake…..CAN YOU HEAR A CLOCKING SOUND COMING FROM THE CENTER CONSOLE?
I have a 96 XJS and when I press the brake at the beginning of the starting cycle …I GET A CLICK SOUND LETTING ME KNOW I CAN MOVE THE SHIFTER FROM PARK TO DRIVE OR REVERSE.
I am assuming my 96 built in late 95 is the same as yours.
I am guessing it has to do with the inhibitor switch.
WHEN I DON’T GET THE CLICKING SOUND IT WILL NOT LET ME SHIFT OUT OF PARK.
Good Luck
Softball60/Paul
Old Aug 11, 2023 | 12:53 PM
rickr's Avatar
Originally Posted by Softball60
Question,
Good Luck
Softball60/Paul
THANKS!! I don't have an issue with my 96', but that's good information to have.
Rick
Old Aug 12, 2023 | 12:24 PM
Thanks for your responses thus far. 🙂
Where is the rotary switch?
Where is the interlock inhibitor?
Old Aug 12, 2023 | 12:56 PM
Mac Allan's Avatar
Do you hear any kind of noise around the gear lever when you first turn on the key and press the brake pedal? If no, check the electrical switch or the wiring connection to that switch located at the brake pedal.
#37 in the illustration here:
https://parts.jaguarlandroverclassic.../brand/jaguar/
OldCoastie
May 3, 2021 01:45 PM
vdpnyc
Dec 9, 2016 06:37 PM
astatedan
16
Mar 19, 2013 08:06 AM
texmanmoore
Aug 5, 2010 01:01 PM
