1995 XJS Convertible Trunk mounted Tail lights
Old Jun 23, 2024 | 09:09 PM
mgraziano1975's Avatar
Default 1995 XJS Convertible Trunk mounted Tail lights
Hi everyone. I have a '95 6.0 Convertible. My wing/spoiler brake light turns on, as do my license plate lights. But the reverse lights and the tail lights located on the rear decklid do not turn on. The taillights mounted in the rear quarter panel work fine. I checked the relay up front. I checked the bulbs. I can't quite get my big hands onto the harness plug that the trunk lid lights connect through to check if I have ground/voltage there.
Thoughts on what could be the cause? What should I check next?
Thanks,
Mike
Old Jun 23, 2024 | 09:58 PM
jal1234's Avatar
The only lights in the trunk lid on US facelight cars are backup, rear fog lights, and license plate lights, no taillights. Test your rear fog lights (low beams on, ignition on, push the button). If they work, it's unlikely both backup bulbs would go out at once. I'd look at the backup light switch or other wiring issues first. Wiring and part location diagrams here:
http://jagrepair.com/images/AutoRepa.../jul1996en.pdf
Jon
Old Jun 24, 2024 | 08:04 AM
Thank you. I didn't know the two inboard red lights on the trunk lid were fog lights. They work. So I'm down to the reverse lights not working. I'll work through the diagram to diagnose.
Mike
Old Jun 25, 2024 | 05:13 AM
uspurs's Avatar
Mike
Mike - just to add that on US cars the lenses closest to the license plate (left and right) are dummies; you probably already knew that, but just in case
Old Jun 25, 2024 | 06:00 PM
I did. I could see there were no bulbs in the back, as well as through the lenses. It was the fog lights that confused me, since I'm new to the XJS. I wondered why I had a fog light switch but no fog lights up front.
Now that I've isolated it to the reverse lights, it opens up more possibilities for me to check, i.e. reverse switch and reverse light relay. I'm hoping it's just a stuck or dirty relay.
Adworboys
Mar 11, 2023 12:00 AM
rickystl
Mar 30, 2020 07:19 PM
Nerobergstr
Aug 10, 2017 08:16 PM
dancer308
Oct 14, 2014 11:32 AM
coastaljag98
Oct 15, 2012 10:19 PM
