1996 Jaguar xjs transmission stop working
Old Aug 2, 2020 | 04:06 PM
Rob6660's Avatar
Default 1996 Jaguar xjs transmission stop working
I have 1996 jaguar xjs 6 cylinder
I was driving and suddenly the transmission stop responding, now does nothing an any gear. Check fluid level it's good.
Need help and advice please.
Old Aug 3, 2020 | 04:06 AM
Out on a limb suggestions:
Being 1996, it would be the ZF 4HP24 electronic controlled transmission. I am not sure of the involvement of the elecktrickery, but understand it is for gear change mainly, but I may be wrong.
The members in the XJ40 and X300 Tech Sections have this trans in their cars, and there are more of them, than 6cyl XJS. NOT wanting to mess you around, but you need answers.
The fact it does nothing at all, and its full of good clean fluid, then the electric components may be the answer. Maybe/? a fuse, oh if only it could be that simple.
I have zero experience with the 6cyl XJS, they simply did not venture this far South. Hence my suggestions for the XJ40 and X300 Tech Sections.
Good luck.
Old Aug 3, 2020 | 05:56 AM
carsnplanes's Avatar
Can you feel if the shift lever is actually moving the cable to the trans? Is the there a trans light on the dash cluster? Did it stop suddenly while driving or after the last drive and you parked it and are now when you start and drive first time in the morning.
Old Aug 3, 2020 | 09:12 PM
Vee's Avatar
Vee
There is a dedicated Transmission ECU. Something may have deactivated it...
Old Aug 6, 2020 | 11:10 AM
Vee's Avatar
Vee
Have you checked Fuse #21 in the passenger side fuse box....Its a 10A for Transmission Power
Andreas Schmieg
US Midwest
Jan 5, 2024 01:39 AM
Rob6660
May 28, 2020 09:15 PM
Remy
Aug 27, 2017 09:53 PM
lush
Oct 30, 2013 05:09 PM
jetlag700
Oct 16, 2010 06:27 AM
