1996 xjs 4.0 false overheat
Old Oct 31, 2018 | 04:28 PM
steve's Avatar
Default 1996 xjs 4.0 false overheat
from cold start up temp gauge goes all the way to H but you can put your hand on valve cover t/stat housing put temp gauge on t/stat hous it read150 deg has new sending unit for gauge system full has heat
Old Oct 31, 2018 | 04:34 PM
Robman25's Avatar
There are two senders on the thermo housing, one has a single spade terminal this is the dash gauge sender, just make sure that it isn’t shorting out. The sensor with the two terminals is the one that is talking to the ECU.
Old Oct 31, 2018 | 04:41 PM
Vee's Avatar
Vee
Ideally if you could plug an OBD2 reader in and see what the ECU is seeing I bet you’d get a confirmation that the sender is bad, not the sensor.
Old Oct 31, 2018 | 05:01 PM
steve's Avatar
inj sensor is fine the temp gauge were a prob when they were new at dealer so replaced it unpluged C reading grounded past H starting to think dash unit only cause turn key off then on and it drops to a different reading
Old Nov 3, 2018 | 04:47 PM
mghirsch's Avatar
had the same issue on my 94 6.0. Ran an extra ground from the flexible circuit board and the problem was solved.
06 xtype wagon
Mar 19, 2018 01:14 PM
EE/ME
Feb 2, 2016 11:59 PM
XK8+XJ8L
41
Apr 28, 2014 04:23 PM
QuervoShots
Apr 5, 2013 02:32 AM
marty.walker
Jun 7, 2007 06:45 AM
