1996 XJS cruise control
Old Aug 30, 2020 | 01:02 PM
Softball60's Avatar
Default 1996 XJS cruise control
Putting out the call for help!!
As some of you know I Finished with the fuel pump install project....successfully as the Kitty purrs very well thank you.
After that I tackled a complete refinish 0f my convertible top system.... Liner, Insulation pad and top....again successful!!!
NOW MY CRUISE CONTROL STOPPED WORKING!!!
I haven’t really driven the car after the pump install as I went directly into complete restoration of the TOP SYSTEM.
I am thinking I might have done something to the speed sensor when I was looking for the brake light sensor.
I get 12v on the connector located in the center console.
I removed the switch and and do my usual resistance test it with my fluke I get 9.0 to 20.0 M ohms of resistance.
Is there another simple way to tell if the switch is good or bad?
As always thanks
Softball60/Paul
Old Aug 30, 2020 | 01:53 PM
Softball60's Avatar
I forgot to mention the resistance test was across #1 and #2 terminal lugs on the switch, tested ion the bench.
Softball60/Paul
Old Aug 31, 2020 | 01:31 PM
equiprx's Avatar
Are you certain that the CC doesn't work?
If you aren't driving it how do you know?
The only CC failures I have found are the CC ECU and or cracked rubber bellows and or vacuum lines.
If you find it is the switch, I have an NOS one.
Old Aug 31, 2020 | 06:08 PM
Softball60's Avatar
Sorry I didn’t explain. After I finished the top I took it for a drive an d found out the cc did not work.
I already ordered a new switch.
Softball60/Paul
Old Sep 1, 2020 | 02:11 AM
Rivguy's Avatar
Did you post a thread on your top replacement?
Old Sep 1, 2020 | 10:30 AM
Softball60's Avatar
RIVGUY,
Sorry, No Posting
I would be happy to answer any questions you have regarding the removal of the top system.
There is a video by a guy called “COVERCATZ”. He did a couple of videos on removing an xjs convertible top system.
Softball60/Paul
RagJag
Mar 10, 2025 12:14 AM
JayJagJay
Sep 1, 2018 10:00 AM
Jackieo123
Jun 3, 2015 02:04 PM
RogB
Feb 27, 2014 01:32 PM
RagJag
Sep 13, 2012 01:13 PM
