1996 XJS HELP ECU
Old Aug 9, 2008 | 08:24 AM
Keith's Avatar
Default RE: 1996 XJS HELP ECU
Dark Knight. Welcome to the site. As with any car sitting for so long, corrosion is your worst enemy. Clean any and all fittings, grounds, and electrical posts. It wouldn't hurt to change all fluids, filters, and put new gas in it. Moisture can collect and cause havoc! Other than the basics, you should be OK, you've got a great car. The only way it would be better is if they had continued the 6.0 liter V-12.
Old Jan 26, 2011 | 02:27 PM
jcuba53's Avatar
I have a 96 XJS 2+2 and had a problem with the ECU. Purchased one from a wreaking yard and, after five tries, found one that worked for $150. During my research on the net, I found two locations that rebuild these units. One in Texas will do it for $450 and gives you a 5 year warranty. That's a lot better than the dealer price. Good luck.
Terry007
Sep 24, 2015 10:36 AM
SouthernGypsy
Sep 23, 2015 04:06 AM
Vee
Sep 13, 2015 12:19 PM
Jaguar_libra
Sep 10, 2015 11:05 AM
SouthernGypsy
Sep 3, 2015 10:54 AM
