84 HE Radio Fuse issue
Old Nov 26, 2008 | 04:59 PM
gjagone's Avatar
Default RE: 84 HE Radio Fuse issue
good day all i have 89 & 86 xjs 4 wks ago i tryed install new radio bought 2 for both cars in the 89 only so far cut plug off factory radio put on new worked about 1 wk went dead lost constance power fuse at box dead both sides not wanting to get crazy finding out why i taped up tp data above worked untill today have my powers tooked one in box n pluged in got some stations but no stereo light hit scan keeps rolling like ant sig not working anyone know is ant one cable frt to back also found on install cut plug off factory conected up but when was pluging to harness plug it had no ground wire i conected right to body someonehave any answers of issues
Old Oct 9, 2017 | 12:11 AM
afterburner1's Avatar
Suggest you get a known 12 vt source and attach it to the radio see if it works. Also good hookup schematics in the Electric Manual for your car. Also check fuses with meter to insure they are OK. Eyeballing may be deceptive. Bad grounds, Antenna corrosion at mast. If the radio works and you have 12vts in the car you have a wiring/fuse problem, but I think you know that! Make sure ground wire is actually grounded; could have high resistance. All connections soldered.
philwarner
Oct 4, 2024 01:37 PM
redrover41
23
Sep 25, 2015 01:33 PM
jehart49
Sep 12, 2015 05:36 PM
motorhead69
Sep 9, 2015 10:04 AM
TexasCat
Sep 8, 2015 04:36 AM
