85 XJS HE Running fine one minute - not the next
Old 09-11-2008, 02:44 PM
ken@britishparts.com's Avatar
Default RE: 85 XJS HE Running fine one minute - not the next
The coil is a solid idea.
Old 09-11-2008, 02:48 PM
If you're spending money on guesses, throw down $25.00 for a fuel injection coolant temp sensor instead of the coil. I'd be running it with a fuel pressure gauge attached, since your descrition of hot restart sounds like low fuel pressure.
Old 09-12-2008, 11:38 AM
Reads like a "classic" misdiagnosis. When the GM ignition module inside a Lucas ignition amplifier fails,your engine will not continue to run no matter how much you stomp on the accelerator. You lose spark and the engine will not run at all.
JarodL
03-07-2024 01:39 AM
toronadomike
08-07-2022 03:41 PM
Raul Lara
09-14-2015 07:31 PM
jehart49
09-12-2015 05:36 PM
tberg
09-07-2015 07:32 AM
Quick Reply: 85 XJS HE Running fine one minute - not the next
