85 xjs no heat
Old Sep 13, 2022 | 03:13 PM
N1PV's Avatar
Default 85 xjs no heat
Flushed system verified control valve working bleed system correctly I am not getting any servo movements air coming from upper vents only I’m now at the amp can I jump a couple of wires to force it in to heat mode thanks jon
Old Sep 13, 2022 | 06:57 PM
equiprx's Avatar
Have you checked for vacuum at the climate control vacuum manifold?
Old Sep 14, 2022 | 08:59 AM
N1PV's Avatar
is the manifold just behind the amp on left side?
Old Sep 14, 2022 | 09:26 AM
Doug's Avatar
There are two wires at the servo (not amp) that you can apply voltage and ground to rotate the servo motor and thus change into heat mode. I'm away from my notes at the moment but I think it's the red and purple wires. An archive search might have something on that. Otherwise I'll look for the info.
Old Sep 14, 2022 | 10:02 AM
N1PV's Avatar
Thanks servo motor bad will not rotate so I loosen rods both slides up then disconnected vacuum from valve under hood blasting heat sending servo to jag-air for rebuild thanks jon
workworkwork
Nov 9, 2015 10:48 PM
dtony
Nov 19, 2014 01:59 AM
JessN16
Jan 8, 2013 06:15 AM
Kalahari
Feb 9, 2011 07:22 AM
tylerw2239
Aug 3, 2008 09:21 PM
