86 XJS v12- driving with open exhaust?
Old Feb 25, 2010 | 10:18 AM
sacrider's Avatar
Default 86 XJS v12- driving with open exhaust?
I had to replace the transmission spring support bushing on my 86, which required loosening the exhaust. It turned out that the exhaust was pretty rusted out and when I put it back together it had lots of leaks. I had to adjust the support bushing so took it all apart again. I was given a good exhaust from a friend who is doing a v8 conversion, but don't have enough room to install it (car has front wheels on ramps, but rear is still to low.
Now to my question - the exhaust has the exhaust manifolds, downpipes and cat converters, but is wide open after that. Can I drive it this way 3 miles to the muffler shop to pay them to put the exhaust back on? I've heard in the past that driving with "open headers" can allow cold air into the exhaust and result in burning a valve.
Any input is appreciated!
Old Feb 25, 2010 | 04:24 PM
S.E.R.E.'s Avatar
driving with an exhaust that is open directly after the headers could result in a burnt valve. But i'm thinking that since you have cats on it that they should retain enough heat and you will be safe. The three mile drive shouldn't be a problem. Anyone else care to back me up?
Old Feb 25, 2010 | 06:53 PM
Brian Felts's Avatar
Cold air only happens on open heads. Truly I ran cats only on a silverado with dual exhaust. There will be no problem driving it.
Brian
Old Feb 25, 2010 | 11:35 PM
sacrider's Avatar
I had a friend give me a hand getting the exhaust back on. I've got a little exhaust leak, but if it persists, I can comfortably drive it to shop to get it fixed.
I agree that i probably could have driven it 3 miles, but since i got it together, I don't have to take the chance.
Thx
BrentGardner
29
Dec 16, 2024 12:13 AM
fast40driver
Apr 19, 2024 07:24 AM
dpappyp
Aug 27, 2015 06:31 AM
Vector
US Lower Atlantic
Aug 26, 2015 05:36 AM
