'86 XJS V12 Getrag 290 swap
Old Apr 15, 2022 | 11:06 PM
Iceboatguy's Avatar
Well, I got the transmission in and took it for a test drive. There's definitely a little bit of air still in the clutch line, as I had to pump the pedal a couple times, but it drives really quite nicely. There's still a couple little things I need to do to get it sorted, like screwing in the shifter boots and putting the exhaust pipes back on, but I'm absolutely in love with it. As someone pretty new to driving stick, as long as the clutch pedal has pressure it's shockingly easy. I'll write up more thoughts later, but I'm extremely satisfied with the support that Ben Thompson at Simply Performance provided throughout the project. If you can find a Getrag 265 or 290 and don't want to do a lot of custom work, I'd highly recommend going with them for a manual swap. If I had to do it over, I would definitely go with the left hand drive pedal box, though. I think I'm probably going to keep the 2.88 rear end for the foreseeable future, and just work on getting everything sorted out and working properly.
Old Apr 16, 2022 | 03:01 PM
jal1234's Avatar
When you get the exhaust on and the boots, etc installed, I'd like to know how much gear whine you have. I have a fair amount in 1st thru 3rd, less in 4th, and 5th is OK with my 290.
Old Apr 18, 2022 | 03:15 PM
Iceboatguy's Avatar
So, I've got a bit of a hiccup -- the gauge cluster has decided to stop working. I think a wire might have been affected in the region behind the radio when I was putting the center console back in. Is there a good diagram of where the wire runs for the instrument cluster go, or some photographs? I'm assuming I'm probably going to have to pull the instrument cluster to sort it out.
Old Apr 28, 2022 | 01:04 PM
Iceboatguy's Avatar
I've got a little whine in first, but other than that it's nice and quiet. There's an appalling rattle when I turn right from either the tunnel cover or one of the sheet metal heat shields, but that should be fixable.
Old Apr 29, 2022 | 08:30 AM
jal1234's Avatar
What gear oil are you using in the 290? I've seen both ATF and synchromesh oil recommended. I'm currently using synchromesh oil, and I'm wondering if a change to ATF might quiet things down.
Jon
Old Feb 3, 2025 | 11:12 AM
Szabadi Kalman's Avatar
As far as I heard the Getrag 290 can handle maximum 290lb ft. of torque (393Nm) - or this info is total nonsense?
5.3 US spec pre 1991 XJ-S might not have more than 393 I dont know. But EU spec V12 XJ-S' has over 300lb ft of torque.
Is that enough also for the later 6.0 V12 XJS as well?
European Spec 6.0 V12 was rated to 354lb ft of torque(480Nm)
DrivenMan seems to no longer has the 6Speed Tremec Magnum conversion kit on offer.
https://drivenman.com/product-catego...72-product_cat
v1rok
Mar 20, 2022 08:21 PM
Adam Stephenson-Tall
Mar 19, 2021 11:41 AM
Andreas Schmieg
Dec 2, 2016 11:30 AM
petemohr
Aug 2, 2015 04:44 AM
Bc xj
Mar 20, 2015 10:50 PM
