88 xjs did the bleed still hot & bouncy
Old Mar 23, 2012 | 06:59 PM
Qgregg's Avatar
Default 88 xjs did the bleed still hot & bouncy
noticed the antifreeze jug was concentrate, so poured in h2o, after draining a little, mix is probally still not correct 78 degrees out tonight. needle is a little bouncy between N and right above N or normal. Did dougs coolant bleed. even loosened the temp sensor on the thermostat housing till i saw fluid. went for a spin needle right above normal fan kicks on after driving a very shout distance. im at a loss.
Old Mar 23, 2012 | 08:18 PM
M90power's Avatar
no need to make another thread.
Old Mar 24, 2012 | 05:26 AM
warrjon's Avatar
If the needle is moving up and down while you are driving - say on the motor way this is normal mine has done this since I replaced the radiator, the temp never gets too high but does go down 1/2 way between C and N then goes just over N. Because the cooling system is working properly the engine is getting too cool on the motorway and the thermostats close and the temp goes back up again.
1100me
Jul 24, 2023 06:10 PM
Mac Allan
Oct 27, 2015 04:49 AM
Jaguar_libra
Sep 10, 2015 11:05 AM
Jaguar_libra
US Western
Sep 9, 2015 04:20 PM
02jagstype
Sep 4, 2015 08:20 PM
